[Attachment(s) from bwholt@... [DynoMotion] included below]
Hello,
I'm having a bit of an issue getting my PWM controlled spindle to work properly. I'm using KFLOP in conjunction with KSTEP boards and running MACH3. I've attached screenshots of my setup in MACH3 and of the spindle and PWM controller I'm using.
My issue is that I can get a scaled voltage in the range of 0 to 5 VDC out of the PWM generator; however, the waveform looks nothing like a standard PWM waveform. It almost looks sinusoidal. The frequency of the waveform is correct per the setup in the example spindle file C:\KMotion432\C Programs\KStep\Mach3\SpindleMach3KStep.c.
I'm using KSTEP JP33 pin 6 as the PWM output. I've connected an oscilloscope across pin 6 and pin 7 while supplying 5 VDC to pin 5.I can set a spindle speed in MACH3 and the voltage across pin 6-7 will scale accordingly. Is the waveform supposed to be quasi-sinusoidal? Have I configured my pins correctly?
BTW, I've also verified ground and signal isolation.
Any insight would be much appreciated.
Wayne
